Batch paste?
Batch paste?
zbischof
Batch paste?
zbischof
I have to put this xrefed legend on 12 different sheets. Not a big deal. But I was wondering is there a way to place the xref on all 12 sheets at the same time in the exact same spot. Like a "batch paste" if that makes sense. That feels like that should be a thing I can do in CAD.
pendean
Community Legend
Community Legend
@zbischof wrote:
...Like a "batch paste" if that makes sense. That feels like that should be a thing I can do in CAD....
Can you "batch paste" in all other programs in Windows with a single action?
You can get into specialized programming to create a custom solution if you want, the forums to ask for guidance with that is over here (start with LISP) https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
Valentin_CAD
@zbischof ,
For 12 sheets, its less time consuming to just xref your legend onto one layout and then use "Copy with Base Point" and paste it on the other layouts (maybe using the corner of a border as your basepoint).
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
zbischof
Thats what I ended up doing. But I figured there was a better work flow out there.
sgauthier
That would be a useful .lips routine if anyone comes across one.  In Bluebeam the tool is called "apply to all pages" (attached screenshot).  Our ideal .lips routine would maybe allow you to select either "all layouts" or "only selected layouts".
pendean
Community Legend
Community Legend
Worth exploring  when you have the time @zbischof
https://www.google.com/search?q=autocad+lisp%3A+paste+in+all+layouts+at+once
https://www.google.com/search?q=autocad+lisp%3A+insert+same+block+in+all+layouts
neaton
Lee Mac has one at lee-mac.com "Copy to Layouts"!
