Announcements
Batch Mirror Multiple DWG's or DXF on the vertical axis
rhys.hughesEDGHC
rhys.hughesEDGHC
I am trying to work out if there is a way to be able to mirror multiple DWG files all at once without having to open each DWG and use the mirror command.
I have tried using macro's but I can't seem to get this to work.
Does anyone has any suggestions to assist?
Cheers
Rhys
Replies (7)
maratovich
No problem. Use this - AutoRunLisp
Specify commands:
_.mirror
_all
0,0
0,1
_yes
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
rhys.hughesEDGHC
Thanks for this - before I purchase a licence can this be used on AutoCAD LT as well? @maratovich
maratovich
No, it won't work in AutoCAD LT.
Neither Lisp, nor VBA, nor programs work in AutoCAD LT. This is an easy AutoCAD, just simple drawing.
www.kdmsoft.net
pendean
Community Legend
Community Legend
@rhys.hughesEDGHC Are you limited to AutoCADLT only? Then you are in the wrong forum and your post needs to be moved.
rhys.hughesEDGHC
Not limited anymore... AutoCAD 2022 installed @pendean
rhys.hughesEDGHC
Hi @maratovich this works like a treat, one thing I have noticed however there are some DXF's that come up with points must be distinct; error: Function cancelled, do you know why this may be?
I have attached the DXF and also included an image to reference:
Cheers
Rhys
maratovich
"the points must be different" ....
What's on the command line?
You need to increase the coordinates of the points
was 0,1 to make 0,1000 or more.
These are standard commands.
You can enter them with your hands one by one and check where the error is.
The first team is a mirror
the second is to select all objects
third - inter
fourth - coordinate 0,0
fifth -corridinate 0.1
the sixth is to remove the old mirror.
Coordinates 0,0 and 0,1 are X,Y
_.mirror
_all
0,0
0,1000
_yes
www.kdmsoft.net
