Hi, I am currently using a simple bat file that opens acad.exe (new version of cad), opens a specific dwg then runs a script. This works well but is a little time consuming as it has to open up a new version of cad when ever the bat file is run.
Does anyone have any ideas on how it can be changed to open up the specific drawing inside the already opened autocad, run the script then exit?
"C:\Program Files\Autodesk\AutoCAD 2019\acad.exe" /product ACAD /language "en-US" "..\..\AutoCad\Xrefs\X-CONTROL OPTION 5.dwg" /b "W:\12_CAD standard\Scripts\Annotative_Control_Line_Output_V2.scr"
EXIT
A quicker way to batch process is with the use of AutoCAD Core Console. Our JTB SmartBatch supports it.
Thanks for the replies but the bat file needs to run by itself. Script pro is good but requires more manual input then what i am looking for.
No, the file is named the same in every job and the file path is relative for that reason.
Even if we use a script to open the file we have the same problem of AutoCad opening a new version of itself rather then a new drawing.
For more background info, we use 12d for all the design and cad for the drafting. Currently i have set it up so all design strings, control lines, contours, long sections, cross sections and typical sections are automatically output with one button.
inside 12d there is a command that runs the bat file which opens can and runs the script.
