basic printing
basic printing
Message 1 of 10
basic printing
I have 50 drawings to print.  All will be to the same printer, same paper size, extents scaled to fit, black and white...  How do I create a default printer that I can print everything to.  Started to look at batch plot but don't see where I can define any of this.  Not even sure how to create a list of files to print.   I don't understand page setup but it seems to be per file which forces me to set all the setting per file.
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Automation like that requires pre-planning.
Assuming you have... PUBLISH command is the way to go. PUBLISH RULE OF THUMB:
1. Launch Publish from a drawing that is not part of the publish set, but is configured with all your possible sheets and plotter options.
2. Bring in all the drawings/tabs to be published.
3. Import the pagesetup desired from the template file (in your case, one set up for exacting desired output) https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
4. PUBLISH.
Message 3 of 10
Patchy
Message 4 of 10
If I were in your spot, I would start by learning how to create and use >named page setups<
Then learn the basics about how to create and use >sheet sets<
You may have to open each individual file and check that the layout(s) you want to plot/publish are all set correctly as far as viewports, title blocks, etc. Takes some time to learn & set up (and plan for how to use in future projects), but after a few runs at it, saves huge amounts of time.
You only have to create the page setup(s) in one file, sheet set manager will use it to publish as many layouts as you choose to add.
For your first few experimental tries, use a page setup with a pdf plotter selected, so if you don't like the result, just delete it and try different settings.
Hope this helps, if not, let us know.
Message 5 of 10
cadffm
Copy one file (no need, but for my sample way, do it)
Go to model tab or to layout tab if you want to plot layouts
Start PAGESETUP dialog, create a new one with a good name and set your settings (printer, paper..).
Save this "Pagesetup.dwg" file.
Close the file.
Start command Publish, create your publish list...
Select all plans in your list, right click in pagesetup column, IMPORT your pagesetup from pagesetup.dwg.
In upper left section set Print to
Printer from pagesetup or similar, i don't know tge right name of this option.
Save the publish list (no need, but for your tests, easier for you if you need to use it again)
Publish!
Sebastian
Message 6 of 10
Thanks for the help everyone.   Got it printed with minimal problems.  Not sure I understand the purpose of sheet sets yet.  There much to learn.
Message 7 of 10
Hi everyone
I have a lot of maps in AutoCAD model space and it is very difficult to print them one by one.
Does anyone have a LISP file that I can quickly print maps together in AutoCAD? (Similar to this video (https://www.aparat.com/v/GRFpO/), but unfortunately the LISP file attached to this video does not work properly)
Message 8 of 10
Hi everyone
Message 9 of 10
maratovich
@Anonymous  написал (-а):
No problem.
1. Use this - Revers
2. Attach a sample of your title block.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 10 of 10
Davidmeade5167
Observer
Observer
To make printing easier, set up your preferred print settings like printer and paper size in a Page Setup in one of your drawings. After that, use the Publish command to handle multiple drawings at once. In the Publish window, right-click the Page Setup column and import the setup from the file you just configured. This way, you won’t have to manually adjust each drawing, and all your files will print with the same settings. It may take some time to set up initially, but it will save you effort down the road.
