Base view tips required
No aplicable
I have made some changes to a large model of which I have created 2D and isometric BASE views of, Is there a way I can select these changes/additional objects to be in the current base views so I don't have to start again?
0 Me gusta
Responder
353 Vistas
4 Respuestas
Respuestas (4)
imadHabash
as i understand your need ... please follow this AKN article that it may help. >> Click <<
Imad Habash
0 Me gusta
No aplicable
I found this article before I posted on the forum.
For some reason that icon does not appear.
I am clicking on the base view to highlight the area, then double clicking in the base view area I am given the following options:
-sElect
-Hidden lines
-scale
-visibility
-exit
there doesn't seem to be any videos on youtube of this matter, I would greatly appreciate some additional advice as it will be saving me many hours work.
Regards
0 Me gusta
imadHabash
>> For some reason that icon does not appear. <<
while you're in the layout and your ribbon is active ( RIBBON command ) select your item by double click to notice that Drawing View appear up there (see below image ) now open it to see Model Space Selection that you ask for.
All the best..
Imad Habash
0 Me gusta
No aplicable
thanks for your help,
I think I may have just realised why this isn't working, I have created a series of pipe isometric views and deleted the 2D projection as only isometric is required.
I believe AutoCAD blocks you from adding objects to the isometric views.
Regards
0 Me gusta
