Base View not updating in Paper Space
sam.thistlewood
Message 1 of 8
sam.thistlewood
I have created a 3D model in AutoCAD and I have projected it into paper space via Layout > Base > From Model Space. I have displayed the views I want and have dimensioned them.
I have then made some changes to the model but the views in paper space do not update accordingly. I have Auto Update on and even when I select Update View it tells me they are up to date and nothing changes.
Is there a fix for this or am I missing something?
Replies (7)
Message 2 of 8
ennujozlagam
try this VIEWUPDATEAUTO set to '1' or refer to this LINK. thanks
Message 3 of 8
ben.saa
Autodesk Support
Autodesk Support
Hi
The description sounds like a corrupted model space.
Copy the contents of the Model space into a new drawing and restart the view-base command.
Message 4 of 8
ennujozlagam
i'm not the OP here? thanks
Message 5 of 8
sam.thistlewood
Thanks, I will try that. It's unfortunately a bit of a faff.
Message 6 of 8
Alfred.NESWADBA
does command _REGEN3 help?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 8
sam.thistlewood
That has not worked. I may just have a corrupt file. Thanks anyway.
Message 8 of 8
Valentin_CAD
@sam.thistlewood ,
You could change the Visual Style and change it back.
Note: The standard REGEN command doesn't work in AutoCAD 3D display modes (Shademode) - visual styles are regenerated automatically as needed. If, for any reason, you need to invoke a regen of a 3D view manually, use the undocumented AutoCAD 2008 (2009) command REGEN3 as @Alfred.NESWADBA  suggested.  >>link<<
Also check your ANNOALLVISIBLE = 1.
Audit and Purge.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
