Base, from model space
bdNMJ9U
Observer Observer
bdNMJ9U
Observer
Observer
Hello, I'm working with AutoCAD full version 2026 and in layout mode the "Base" from model space function doesn't work at all, neither in new drawings created in 2026 or in previous versions 24/25
imadHabash
If you're talking about VIEWBASE command ...
  • The VIEWBASE command only works with 3D solids and surfaces. It will not work with Polyface Meshes or 2D objects.
  • Drawing corruption can cause various issues.. Run AUDIT and PURGE commands.
  • VIEWBASE depends on Autodesk Inventor Server, If these are missing or corrupted, the command will fail.
Imad Habash
bdNMJ9U
Observer
Observer
I understand that this command only works with solid or surface materials, and I've also tried the AUDIT and PURGE commands. "VIEWBASE depends on Autodesk Inventor Server"—what does that mean?
paullimapa
according to this Autodesk post, since you're running 2026, there should be a folder installed here:
C:\Program Files\Common Files\Autodesk Shared\Inventor Interoperability 2026
Or you may need to log into your Autodesk account and install the Inventor Interoperability extension for 2026
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Opening-a-drawing-...
Paul Li
IT Specialist
@The Office
BhaskarMurari
@bdNMJ9U Check for any updates available for AutoCAD 2026. (Install AutoCAD 2026.1.1 or newer version )
lauri_barnhart
Hello, @bdNMJ9U,
Did the information provided by @paullimapa or @BhaskarMurari help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
