Base command in Autocad
mariustipa
Message 1 of 17
mariustipa
Hi
The base command in Autocad is not working since 2023 version. Base from Model Space or Base from Inventor ... is doying nothing.
Also there is a loop in installing something when launch Base command but I got no clue what.
Any ideea please?
Replies (16)
Message 2 of 17
j.palmeL29YX
What command are you talking about? Do you mean the command VIEWBASE?
Jürgen Palme
Message 3 of 17
imadHabash
Just to remind that you should have a Solid object while using this command.
You may find some help HERE.
Imad Habash
Message 4 of 17
mariustipa
This is the command - see attach
Message 5 of 17
mariustipa
The Inventor plugin INVINTEROP_2026.exe can't be installed. It takes me into a continuous loop.
It is amazing how they make this software really a garbage.
See attach please.
Message 6 of 17
paullimapa
May want to post that inventor error in the inventor forum and get better feedback
Paul Li
IT Specialist
@The Office
Message 7 of 17
paullimapa
Questions
1) What AutoCAD version are you running now?
2) Do you have the latest updates installed?
Enter About command do a screenshot and share it here
3) Does the problem occur on all dwgs or a specific dwg?
Can you share a sample dwg file?
Paul Li
IT Specialist
@The Office
Message 8 of 17
pendean
Community Legend
Community Legend
@mariustipa Please share your actual DWG file (and Inventor file) here when you get a chance: it's not called BASE command so your title needs to be changed to BASE VIEWS if you want to attract the correct assistance. Which option did you select?
Did you restart your PC and ensure your login is at the local ADMIN level or higher? That's needed to resolve your installation issue.
Message 9 of 17
CGBenner
@mariustipa
You image is showing that the software needs for your system to restart in order to complete the installation.  Have you allowed the restart to happen?  If so, does the error persist?
Chris Benner
Message 10 of 17
mariustipa
From Model Space.
Message 11 of 17
mariustipa
Brief:
Thank you all!
Indeed the Inventor Plugin needed to be install. Then one need to change Registry by deleting the AutoUpdate Key here:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\AutoUpdate
Step 2:
Install Inventor Interoperability from here:
https://manage.autodesk.com/products/updates
Step 3:
Mandatory Restart.
Message 12 of 17
mariustipa
Yes it takes me into a restart loop. I have explained all at the end - last post.
Message 13 of 17
mariustipa
Actually it is called BASE from the menu.
Message 14 of 17
mariustipa
The Inventor Interoperability 2026.exe is just a plugin inside Autocad and it allows to make projections and sections. This is not about Inventor itself.
Message 15 of 17
mariustipa
Of course! I did not said the contrary. But the plugin is needed for Base Command inside Autocad.
Message 16 of 17
mariustipa
The restart option leads you into a loop. To solve this the Registry needed to be edited by this path:
Message 17 of 17
j.palmeL29YX
For using the viewbase command properly AFAIK it is not necessary to install any plug in nor to change settings in the registry. After a standard installation of AutoCAD the command should work well (assuming there are 3DSolid objects i your current drawing).
 Perhaps you should reset all AutoCAD settings to default or perform a clean uninstall and new installation of AutoCAD.
Jürgen Palme
