Bangla font showing correctly in Auto CAD 2018 but font broken in printout
Sir,
I am using auto cad 2018. Bangla font showing correctly in cad file but not printing or pdf making properly. Bangla Font is broken in output.
gotphish001
What do you mean by broken? It shows something different, doesn't show at all, shows some other font?
Nick DiPietro
Cad Manager/Monkey
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Is it possible to share your font with me so I can try it on my side?  There are some known issues with some fonts including most Arabic fonts.
Usually, the workaround is to print to a PDF using a 3rd party driver such as FoxIt or PDF-Xchange.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem or question. Did you try one of the other PDF drivers? Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Sir,
Here is the file are attached. The Diversion ahead sign. Please see the attachment.
john.vellek
Hi @Anonymous, Thanks for the files. Please also give  me the font that is not behaving when printed. That way I can test on my side to make further recommendations.
John Vellek
