Background Mask
falconbird
Background Mask
falconbird
I am using Acad2013. My background mask is not working on my properties dialog box. I get the 3 periods at the end but  when clicking on it, nothing happens. Is there a variably that needs to change? It is an Mtext and works when I text edit.
0 Me gusta
Responder
594 Vistas
7 Respuestas
Respuestas (7)
braudpat
Hello
Very strange, the Mask option must run from the "MTEXT" properties dialog box !
Just a quick idea: have you installed the SP2 on your 2013 ?
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2013-service-...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
0 Me gusta
rkmcswain
Sounds like the "Background Mask" dialog is "off your screen" (Do you have to press ESC to keep going after you press the "..." button?)
Follow this tutorial to get it back.
0 Me gusta
braudpat
Hello
+1 with R.K. McSwain
Patrice BRAUD
0 Me gusta
falconbird
I think I am now explaining my problem.
I have the Properties palette displayed on my screen. When I list the properties of the selected object (text that is an Mtext) under the TEXT tab on the Properties palette the background mask is displayed as No or Yes (default is No). When clicking on the background mask 3 periods at the end of the row appears. Nothing happens when clicking on the 3 periods. At that point I should have an option to mask the text that was selected just as I would have if using the Mtext command. Yes I can change my option with the Mtext command.
0 Me gusta
falconbird
Just found out that it works on Acad2012 and not on Acad2013. Why is that?
0 Me gusta
Jonathan3891
Thats very strange. Have you installed any service packs available for 2013?
Jonathan Norton
Blog | Linkedin
0 Me gusta
falconbird
Sorry for the long delay in responding. Gave up on it and installed AutoCAD2015. The problem I was having in AutoCAD2013 was not in AutoCAD2015 until again something happen and now it's not working on AutoCAD2015. This is very frustrating. I think I have install all the updates to AutoCAD2015. PLEASE someone HELP!!!
0 Me gusta
