background brightness changes with viewpoint
Karol-Or
Message 1 of 9
Karol-Or
When i move the viewpoint, the background either whitens or becomes dark agin.
Tried Keep scene upright - no use
I want to cancel this setting and that the background will be always black
Replies (8)
Message 2 of 9
paullimapa
could you do a couple of screenshots showing the background color turning white when you're changing the viewpoint?
Paul Li
IT Specialist
@The Office
Message 3 of 9
imadHabash
To keep your AutoCAD background black in 3D, change the uniform background color in the Options dialog. Type OPTIONS > Display tab > Colors > select 3D parallel / Perspective projection and set the color to Black.
Imad Habash
Message 4 of 9
Karol-Or
Found, it's the PERSPECTIVE command. it also cancels the change in background brightness.
Message 5 of 9
paullimapa
Similar to @imadHabash reply post but for 3D perspective projection:
Paul Li
IT Specialist
@The Office
Message 6 of 9
Karol-Or
Thanks, solves, but PERSPACTIVE variable keeps resetting to 1 and it canceles these changes.
Should i post a new question?
Message 7 of 9
paullimapa
I'm confused by your response.
Are you saying that after the change under Options, when Perspective is set to 1 the background now stays as black?
But the PERSPECTIVE variable on its own always resets itself to 1 even after you've enter a 0?
Paul Li
IT Specialist
@The Office
Message 8 of 9
pkomatlapalli
Hello @Karol-Or
Did the information provided by @paullimapa and @imadHabash help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Pavan Kumar | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
Message 9 of 9
imadHabash
That means there is a certain outsource installed app or plugin that automatically change this value.
Imad Habash
