Autoscript and ScriptPro for Autocad 2017 not working
toganivalu.graham
toganivalu.graham
Hi
I have just updated to 2017 and in doing so;
  1. autoscript does not work, returning a "Unknown command "AUTOSCRIPT""
  2. Scriptpro is not stable and has been eratic, working on some drawings and failing on others.
Is this an inherent issue with 2017?
Can anyone point me in a better direction to a solution?
Cheers.....
GT
Adelaide - SA
Australia
tramber
Do you know this one ? SAS (superautoscript)
It is not in English...
About Autoscript : isn't that an external application ? Did you APPLOAD it, at least ?
I'm sure someone who knows it wil help you to find the file to load if you don't know.
pendean
Community Legend
Community Legend
Autoscript is a third party tool you actually have to install / load first: it appears its not installed if you get "unknown" http://www.cadig.com/download/download.php?pid=41
JTBWorld
Our SmartPurger is an option that works to do scripting in AutoCAD 2018.
https://jtbworld.com/smartpurger
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
toganivalu.graham
Hi Dean,
I have loaded this, and loaded its cui as well as the arx file. (Similar to when I had loaded this in previous versions of AutoCAD). The Autoscript menu appears but wen lauching (either via an 'autoscript' in the command line or via the menu drop-down, I get the 'unknown command' error.
Thought I was missing something....
GT
Adelaide - SA
Australia
pendean
Community Legend
Community Legend
I'm not having any issues running it here, I use it all the time.
Reach out to the author/creator of Autoscript for support.
Valacho_H
I know this is old, and you must have solved the problem or found a different product to do what you need, but when we ran into the same problem this is how we solved it.  Perhaps it will help others, since I was looking for the solution online, and found this thread, but nothing particularly helpful in it.
In our case we were running a macro (I don't know if this is always the case with AutoScript).  In that case, in addition to making sure the location hosting the script called by "Autoscript" is in the "Support File Search Path" in the AutoCAD options, you also need to make sure that path is added to the "Action Recorder Settings" - "Additional Actions Reading File Locations" so the macro created can be found.
Once that path is added, go to the "Manage" tab in AutoCAD, and in the "Action Recorder" pane on the ribbon, there is a drop-down box, which is likely empty.  Click on that drop-down box and select your script from the list (which populates after you point to it in the options) to make that script the current item in the "Play" list and then try running AutoScript again.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
