Automating technical drawing
EmreYucel34
EmreYucel34
Hello, mold design and manufacturing is being done hydraulic manifold, the main design company designs the main design with PTC CREO and shares us the technical drawing to be encrypted and we enter the dimensions by analyzing from the table in each password file, then we make 3D drawing in ACAD and create tool paths in MasterCAM, this process takes a lot of our time, constantly analyzing from the table is repetitive, I tried to automate it in Exel, but entering 900 thousand items one by one is very tiring, how can I automate this process in ACAD and Autodesk software, thanks in advance for your help, good day
0 Me gusta
Responder
518 Vistas
3 Respuestas
Respuestas (3)
Washingtonn
From you post, it doesn't appear you have a problem generating the 3D drawings in AutoCAD. It sounds like the steps you need to perform prior to creating the drawing and what you steps you need to perform after the drawing has been created need to be addressed in forums related to PTC CREO and MasterCAM software.
0 Me gusta
EmreYucel34
Hi Washingtonn,
The important thing is that we can actually read the encrypted DWG drawings by finding a solution to read them by finding a solution, if we can achieve this, we can do the other steps in order, it will be very good if we can scan the DWG by scanning the passwords.
0 Me gusta
baksconstructor
The point is not very clear. I recommend attaching an example. At least a small part.
0 Me gusta
