Automaticly drowing in autocad using excel
CsBakonyi
CsBakonyi
Community Visitor
Community Visitor
How to draw a circle around the existing number in autocad using excel?
Kent1Cooper
Do you have an Excel file that you need to get information from in order to do this?  What is the format of the information in it?  Is the "existing number" a Text object?  Mtext?  A Block?  Something else?  Is the User to select it, or is the Excel file's information supposed to direct AutoCAD to find it?  Explain what you are starting with, what you expect the User to do, how an Excel file should be involved, what should be the result, etc., in as much detail as you can provide.
Kent Cooper, AIA
pendean
Community Legend
Community Legend
@CsBakonyi wrote:
...draw a circle around the existing number...
TEXT or MTEXT? Or is this a block attribute and it might just be simpler to replace or redefine the block?
