Automatic Angular Dimensions
No aplicable
      I am trying to create a 90° protractor in autocad and I want to dimension it every 0.2°. Is there a way I can automatically do that?
I have attached the dwg file.
Swami
0 Me gusta
Responder
Soluciones aceptadas (1)
935 Vistas
7 Respuestas
Respuestas (7)
imadHabash
make one dim then use ARRAY command if you have fixed distance.
Imad Habash
0 Me gusta
No aplicable
Thanks. But I do not have fixed distance. I have a fixed angle. Sorry I am a little new to AUTOCAD. Maybe I didn't understand or I am doing something wrong!
0 Me gusta
No aplicable
I tried just now and got an array of angles but they numbers do not change. When I tried to array the dimension 0.2 degrees , it just shows 0.2° everywhere and does not increase progressively.
0 Me gusta
No aplicable
File Attached
0 Me gusta
imadHabash
please forget my idea about ARRAY, my understanding for your need was wrong.as i understand it now i'm afraid that you have to do it manually.
Imad Habash
john.vellek
Solución aceptada
Hi @Anonymous,
Just thinking out loud....What if the text was a field designed to capture the angle of the line? You could try a copy-rotate for additional lines at the various angles. Perhaps if you had the field and the line it could even be arrayed. I tried this, exploded the array, performed a Regen and the values updated as expected
John Vellek
No aplicable
Thanks John. Worked as a charm.
