Anuncios
Automate Data Extraction to Excel
No aplicable
I can extract the data manually from a DWG file to an Excel File using the Extract Data wizard. However, since I will be getting 100's of DWG files daily, I don't want to manually do the extraction part. Is there any way I can automate the extraction of a DWG file into Excel Files. So I can loop through all the files?
Better If I can directly insert into SQL SERVER tables.
0 Me gusta
Responder
1.766 Vistas
2 Respuestas
Respuestas (2)
AllenJessup
I don't know of any OOTB method to do this. Check out THIS thread and see if any of the suggestions or link help you.
Check out THIS also
Allen Jessup
CAD Manager - Designer
No aplicable
There are many automated data capture software available which can sort out your issue.
0 Me gusta
