autolisp program
autolisp program
autolisp program
how to put the returned area value (from the prompt window) in an autolisp variable, I use the command MEASUREGEOM to get the area.
Valentin_CAD
@Anonymous ,
Welcome to the AutoCAD forum.
Check the Visual LISP, AutoLISP and General Customization Forum:
Also check this link:
http://www.lee-mac.com/arealabel.html
http://www.lee-mac.com/areastofield.html
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
I use the command MEASUREGEOM (quick option in autocad 2021) to get the area, the area command not working with blocks in autocad .
the goal of my program is to calculate the areas of each block in a drawing and export the text inside the block with the block area to a file.
Valentin_CAD
@Anonymous ,
@Kent1Cooper  provided a solution to a similar topic:
Visual LISP, AutoLISP and General Customization Forum.
Emilio Valentin
