AutoLisp for displaying only the Z value of multiple points (displaying RLs)
No aplicable
Hey guys,
I'm a Civil Engineer by trade so have limited knowledge using AutoCAD and LISPs. I'm chasing a LISP that can display the  "Z" value/RL of multiple points (over 100 points) which I shot while surveying out in the field. I have used a Software Programme called "Terramodel" but am sure there is a way to do it in AutoCAD. I'm not too concerned about about text height, rotation, layer type etc as I can easily modify this in the properties section once all "Z" values are selected.
Hoping that there is already this script available to download Emoticono feliz
0 Me gusta
Responder
1.371 Vistas
2 Respuestas
Respuestas (2)
No aplicable
I am not too sure but please see the link below if this is what you are looking for.
https://forums.autodesk.com/t5/autocad-forum/solution-for-level-elevation-r-l-e-l-spot-dimension/td-...
Hope this helps.
0 Me gusta
imadHabash
you can achieve this issue by using QSELECT command . just fill the dialog with the proper values that serve your mission .
Imad Habash
0 Me gusta
