I got a notification from the 'Autodesk Trusted DWG' icon so I clicked on it (I wasn't able to see what the notification said before clicking on it). And a notepad with the txt extension popped up. The content of it is big but this is the beginning of it (the onlt one that matters, I guess): "Card name: NVIDIA GeForce GTX 1660 Ti with Max-Q Design
Driver version: 26.21.14.4219
Tuning Date:
Virtual device: gdi15.hdi (Software)
The card and driver does not meet the minimum requirement."
If anyone want to see the rest of the message, I will attach a video.
If anyone has an idea of what I should please tell me. I'll higly appreciate any advice!
Thank you for your time! I also attached the txt extension.
May I ask what the "Autodesk trusted dwg icon" is?
The message about "This file is a Trusted DWG" only appears when you open a dwg-file that was modified with an Autodesk product. The opposite is the message "Non Autodesk DWG. This DWG file was saved by a software application that was not developed or licensed by Autodesk" shown as dialog as well as in the command-line ... which means this dwg-file was modified by a none Autodesk product.
But this is not shown as icon, it's just text in the command-line ....
- alfred -
