Autodesk Certified Professional in AutoCAD for Design and Drafting Certification
handjonathan
handjonathan
Be the first in the market with our latest industry validated credentials by taking the Autodesk Certified Professional in AutoCAD for Design and Drafting beta certification exam for $35*.   
The Autodesk Certified Professional in AutoCAD for Design and Drafting beta exam is ideal for professionals and students who possess leading edge knowledge and skills in AutoCAD. This industry validated certification created by Autodesk is intended for AutoCAD users who have mastered associated workflows, processes, and project objectives, in an academic program or professional environment. By taking a beta exam, you have the first opportunity to earn what likely will become the next Autodesk AutoCAD certification.
If the exam becomes an official Autodesk certification exam and you earn a passing score, you’ll get:
  • The Autodesk Certified Professional in AutoCAD for Design and Drafting certification
  • An official digital badge and certificate
Limited spots are available, and they’ve been filling up quickly, so please apply soon if you’re interested. If you have already scheduled an appointment, thank you for taking your first steps to certification.
Apply here https://autodesk.useclarus.com/apply/application?id=465
For more information about the beta exams and associated policies, please see the FAQ and review the guides linked below.
Exam Guide |  Exam Objectives 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Responder
3.718 Vistas
14 Respuestas
Respuestas (14)
dany_rochefort
@handjonathan hi John, will we have to re-qualify each year to keep our cerificate valid ?
dbroad
Technically the exam guide is incorrect on question 3 in a least 2 ways:
1. There is no matchproperties command. The command name is matchprop.
2. Selecting layer and dimension style would not match those properties.  It would match every property but those because they would be unchecked in AutoCAD by selecting them.
On the home tab of the OOTB AutoCAD ribbon it does have a Match Properties button.
Architect, Registered NC, VA, SC, & GA.
handjonathan
@dany_rochefort Thanks for asking this, If the candidate passes the AutoCAD ACP beta exam and earns a certification, the certification is valid for 3 years. After that time, retesting is required to recertify.
Jonathan Hand
handjonathan
Hi @dbroad Thanks for the comments on this. The guides are intended to be a representation of the type of exam questions that will appear on the exam (multiple choice with graphics, multiple choice with multiple answers, etc). We are reviewing the content now and revise it accordingly.
Jonathan Hand
0 Me gusta
dbroad
Thanks. Glad I could help.  BTW, Just invoking the matchprop command won't take you to that dialog and many would be unfamiliar with it.  In addition, even though the checkmarks are generally applicable, most of them won't actually apply anyway. For example, you would need to select a dimension and then settings.  If you selected a line, then the dimension checkmark would be irrelevant.
Changing the settings isn't necessarily a good idea either because those settings are sticky.  So they could be easily forgotten the next time matchprop is used.
For dimensions, I usually use the properties palette to select the dimension style.  I also have a command alias for updating dimension to the current style. (defunc c:up()(command "dim1" "up")). The type-in for that is now "dimstyle apply"
rcardona42
@handjonathan  Are Beta test results really taking 6 months to get? I took the test back on April 7th and have not gotten any type of results notice.
0 Me gusta
dkindrew
when are the test results going to be released?
0 Me gusta
brandyrodriguez
I just received my results today 09/06/2023, notice of results was sent out via email.
0 Me gusta
dkindrew
I got the email saying they were ready, but no results yet.
0 Me gusta
brandyrodriguez
I received my email this morning and when I attempted to check the results nothing showed up either, a few hours later I went My Dashboard | Autodesk from Autodesk website I could see results.
0 Me gusta
dkindrew
i did that. still nothing. and i just check before i posted. ill check again tomorrow
0 Me gusta
geraldjosephk
They should be out now
0 Me gusta
theilt20uae
Observer
Observer
when are theilt20 test results going to be released?
0 Me gusta
brandyrodriguez
I received email notification in September, you can also just sign in to your Autodesk account (same email you used to take test), select my dashboard and view your current certifications.
0 Me gusta
