autodesk audocad suite 2015 install
For speed reasons I did a basic install on a system now I want to go back and install additions programs and components. Do I just launch the main installer and do it from, there or is there a better way? I am going into it like a new instakll now to see. But its very slow over the network.
wispoxy
  1. Close all instances of AutoCAD.
  2. From the Windows Control Panel select Add or Remove Programs.
  3. From the Add or Remove Programs dialog box, select the latest version of AutoCAD and click the Change/Remove button.
  4. On the AutoCAD Installation Wizard, click Add or Remove Features.
  5. On the Manufacturer Content Selection page, select all the manufacturers you wish to install. Click Next.
  6. On the Select Symbol Libraries page, click Next.
  7. Click Update.
Ok. I will try that again after this install failes if it does. It did give erros butm is still going. Its slow as its on an ointernet share. I am also copyying the entire thing from the internet to a seperate disk just in case but, thats taking forever to. 200+ GB. I see there are 2 directors one is 64 bit and 32 bit. Did I still need the 32 bit x86 even on a 64 bit sys?
wispoxy
Just keep the 32bit anyway, but use the 64bit if your computer can handle it.
