autodesk 2014 not responding
No aplicable
So i had to 3d object using revolve for my college homework. I made half of it using like 200 lines and then i revolved it. and that is where troubles began. When ever i try to move that 3D object my Autocad frezes and stop responding. Object is fairly complex (around 200) lines and i didn't use join command before i revolved it. I tried reinstaling, but i didn't work.
Also my PC spec are way higher whan minimum: Athlon II x4, 8 gigs of ram and amd radeon 6770.
I hope someone can help me
0 Me gusta
Responder
276 Vistas
1 Respuesta
Respuesta (1)
M_Hensley
Your model contains nearly 500 revolved surfaces. You should simplify your profile and make a closed polyline of one half the shape then revolve that into a solid. If it needs to be hollow like a tube then make another profile for the inside and revolve that then subtract it from the outer shape.
0 Me gusta
