Autocad won't draw lines
Responder
Soluciones aceptadas (4)
11.099 Vistas
23 Respuestas
Respuestas (23)
ennujozlagam
hello, can try this , in the command prompt type UCS , then select World then ENTER. in the command prompt type PLAN and enter, now draw a line again and see if helps. thanks
0 Me gusta
No aplicable
This did't work. I've already redownloaded Autocad is this some kind of bug it really won't let me plot coordinates even if I add @ in front.
0 Me gusta
Alfred.NESWADBA
what does AutoCAD show you when you run ZOOM EXTENTS afterwards?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
ennujozlagam
Solución aceptada
try this line,  @5<8 , enter
0 Me gusta
No aplicable
Nothing. Should I redownload Autocad again ?.
0 Me gusta
ennujozlagam
Solución aceptada
hello, i understand what you mean it works with me, try to install latest updates from autodesk and see if helps. thanks
0 Me gusta
Alfred.NESWADBA
Solución aceptada
No, not now as we don't have enough informations.
You can try to disable hardware acceleration, command _GRAPHICSCONFIG
You can try to reset settings to default as described >>>here<<<
If nothing helps, can you please save the dwg-file and upload it here so we can look into the dwg-settings?
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I updated Autocad it didn't work. Then reset settings to default also didn't work. Is this a problem with newer versions of Autocad because I use Autocad's 2019 version for Windows and 2018 version for Mac. Should I download the 2016 version ?.
0 Me gusta
ennujozlagam
hello, no harm in trying just install and see if any difference with the versions and if will works well. thanks
0 Me gusta
Alfred.NESWADBA
have you tried to disable hardware acceleration?
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
It didn't work. What's wrong with Autocad ?. Why won't it plot the coordinates, I can draw lines using the mouse but not using the command line, and I need to use the command line to draw because it's required by my professor.
0 Me gusta
ennujozlagam
Hello, can you use pline instead of line and explode later to become line and see if helps . We settle later your issue. Thanks
0 Me gusta
No aplicable
Hi thank you for replying, I can use pline but it doesn't plot the first point to the coordinates I've typed instead it plots it to wherever the mouse pointer is.
0 Me gusta
ennujozlagam
hello, can you post your drawing so we can check. thanks
0 Me gusta
ennujozlagam
can you try this PICKADD set to 2, PICKFIRST set to 1. thanks
0 Me gusta
No aplicable
How do I do this ?. I'm sorry I'm new to Autocad.
0 Me gusta
ennujozlagam
hello, in the command prompt just type PICKADD set value to 2, and same as PICKFIRST set value to 1 then type regenall > enter, try again your line command. thanks
ennujozlagam
hello, any updates from you???. thanks  Emoticono feliz
No aplicable
I'm going to download the 2017 version and delete the 2019 version.
0 Me gusta
