AutoCAD Forum
Autocad very slow on workstation
6 REPLIES 6
913 Views, 6 Replies
We have some problems with autocad being slow.
We searched on the forums for solutions but we can't find any that fixes this problem.
Hardware Specs
Model HP Z420 Workstation
Processor Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz - 6 cores
Memory 32 GB
Display NVIDIA Quadro K4000
We can see autocad uses only 1 core @ 100%
We tried new drivers/reïnstall/updates etc.
Opened the files on a laptop which runs it smooth?
Any idea how we can make this workstation run autocad fast?
Kind regards,
Mark Heijnemans
Tags (3)
6 REPLIES 6
pendean
Your AutoCAD variant and year version is...?
Your WIndows OS is...?
You store your files where? How are you connected to that location?
Post a screenshot of your GRAPHICSCONFIG command pop-up as well.
Libbya
You're also posting on the Dynamic Blocks forum and your post has nothing to do with Dynamic Blocks.  Installation and Licensing or the general Autocad forum would be more appropriate places to post your question.
in reply to: Libbya
Hi Thanks for the fast replies, and sorry for putting it in the wrong category.
We are using : Autodesk AutoCAD 2018 - Student Version
Windows 10 versie 1803
Autocad is installed on a local SSD drive, and my drawings are on a fileserver which is a mounted drive to my PC.
Kind regards,
Mark Heijnemans
Erense
First, AutoCAD can only address one core in most cases. You have to tell it to, in some cases, use a second core.
You can do this with WHIPTHREAD.
Second for a Xeon processor (mostly 6 cores) and Hyperthteading enabled om the PC your cores will be 12 cores.
100% Processor/12 cores is only (approx.) 8% usage per core. So 100% core is easily reached.
Try disabling Hyperthreading on your pc and activate WHIPTHREAD in AutoCAD.
See if the performance improves.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 If you move the files to your local drive do you still have performance issues?  What kind of file server is in play and where is it located?
Is your AutoCAD 2018 fully updated?
John Vellek
john.vellek
HI @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
Technology Administrators
