Autocad units in millimeters - Show areas in objects in Meters
No aplicable
I'm working with my Units in millimetres, but when I want to see the area of some object like a polyline I want that result in METERS, it's possible to do that ?
Thank you
Hugo
0 Me gusta
Responder
4.038 Vistas
20 Respuestas
Respuestas (20)
imadHabash
you can get it by LISP files existing in the web and herewith one that i usual use.
(defun drtxt (/ rn tx ls vl lt ht lb hb nr pt)
(setq tx (strcat "Area: "
(rtos (/ (getvar "area") 1000000) 2 2)
" m2"
rn (getstring "\nRoom Name: ")
(setq ls (list (cons 1 tx))
vl (textbox ls)
vl (cadr vl)
lt (car vl)
ht (cadr vl)
vl (grread T)
nr (car vl)
pt (cadr vl)
(princ "\nInsert Point: ")
(while (/= nr 3)
(command "redraw")
(grdraw pt (setq pt (polar pt 0 lt)) 7)
(grdraw pt (setq pt (polar pt (* pi 0.5) ht)) 7)
(grdraw pt (setq pt (polar pt pi lt)) 7)
(grdraw pt (polar pt (* pi 1.5) ht) 7)
(setq vl (grread T)
nr (car vl)
pt (cadr vl)
) ;end while function
(command "-mtext" pt "w" 0 rn tx "")
(redraw)
) ; end drtxt function
(defun c:pla ()
(setvar "cmdecho" 0)
(while (setq et
(car
(entsel "\nSelect polyline: ")
) ;end car function
) ;end setq function
(command "area" "o" et)
(drtxt)
) ; wnd while funtion
(setvar "cmdecho" 1)
(princ)
) ; end c:pla function
(if (eq (getvar 'savetime) 0) (setvar 'savetime 7))
Imad Habash
0 Me gusta
No aplicable
how can I load this rotine to be permanent and what command do I use to work with that ?
0 Me gusta
imadHabash
put the data in a .txt file then rename the extension to lsp then from AutoCAD type APPLOAD command.
then type PLA
Note:
if do you want this lisp to be always there... put the file some where in folder then from APPLOAD command go to the briefcase  to always be there.
Good Luck..
Imad Habash
0 Me gusta
No aplicable
I did it, it works very well, but when I closed my AutoCAD and open again, it's not there, I have to load again,
there is any way to be permanent ?
Thank you
0 Me gusta
Patchy
Use APPLOAD, and find an icon looks like a suitcase, click it and add your autolisp in there.
0 Me gusta
imadHabash
as i told you in previously add the file to the briefcase from AP command.
Imad Habash
0 Me gusta
No aplicable
this way I already did it :cara_con_una_leve_sonrisa:
Everything it's working
Thank you
Hugo
0 Me gusta
imadHabash
You're Welcome.. :cara_con_una_leve_sonrisa:
Imad Habash
0 Me gusta
No aplicable
another one to complete this work :cara_con_una_leve_sonrisa: it's possible to link this Area to a Polyline in the way that if we change the polyline this area will be automatic update ?
Thank you
0 Me gusta
imadHabash
Yes... you can by FIELD command or use another lisp routine like >> Link >>
i hope it's help
Imad Habash
0 Me gusta
No aplicable
I know the FIELD command and I use, but it take some time because I work with the units in millimetres and want the areas in Meters, that's why my question because this lsp to put names and areas it's great :cara_con_una_leve_sonrisa:
0 Me gusta
pendean
Community Legend
Community Legend
FIELD command, OBJECT selection, Conversion Factor...
There is also a freeware on the Autodesk Exchange site called AREA OBJECT LINK that may be a good alternate as well.
0 Me gusta
Patchy
1m sq. = 1,000,000 mm2
Dean missed it
0 Me gusta
sthompson1021
Must be new math your usingEmoticono muy feliz I was always taught that 100x100=10,000Guiño
0 Me gusta
Patchy
Must be new math your usingSmiley Very Happy I was always taught that 100x100=10,000Smiley Wink
Really m, dm, cm,mm
a meter is how many mm Mr. Thompson????  Then square it
You guys confused me.
0 Me gusta
sthompson1021
Emoticono avergonzadoOK, can I tuck my tail between my legs and run away now. I'll stick to my feet and inches.
0 Me gusta
pendean
Community Legend
Community Legend
LOL, either way, the feature wanted is available in FIELD for the OP.
0 Me gusta
Patchy
Field needs some improvements, it's too slow because going thru several clicks to get Field.
There are a bunch of add-on but I haven't found one that can do a conversion like that, I know Customization group can whip it up in a few minutes.
0 Me gusta
pendean
Community Legend
Community Legend
FIELD is slow if you use it OOTB and need to use it 20+ times in a day, every day, all week long: there are many tips around these forums to edit the windows registry to pre-set many of the default options that do not work, as well as excellent Diesel macros to help automate other tasks.
Plus one or two freeware on the Autodesk Exchange site and for-purchase from third party providers.
Honestly, it's up to the OP's comfort level to pick the solution that helps them get the task done. All we can do is present options without shooting down others ideas.
*EDIT*: hope it doesn't read as an attack Patchy, not meant to be. No emotions in my writings as you know.
*UPDATE* the free add-on I talked about from the Autodesk Exchange website
0 Me gusta
