autocad to pdf
I have elevations done by hand, scanned them, opened them in photoshop and I colored them in photoshop. I then created a pdf of these elevations (pdf because it retains the color while jpeg or tiff changes the color significantly). I then xref these pdf elevation images into my autocad file in the model space, scaled them up to the right scale. I then print pdf them in the paper space as part of the whole set (which is a mix of cad and images). When I opened the pdf file everything is good except the pdf elevation images are not clean -- they have some extra lines (or bubbles) at different spots of the images, mostly around outer edges of the bldgs or single lines. This issue doesn't really happen all the time, only every now and then. I don't really know what causes this to happen because I always use the same process. But if I open the pdf file in bluebeam the elevations are fine. Any idea what might be the cause of why this happens.
