AutoCAD to PDF print problem
ronualdo_neral
ronualdo_neral
I have a problem with regards to printing from CAD to PDF format.
I try all the methods I know  but none of them get the result I want which is:
  1. In 100% view all lines are 100% visible and not faded.
  2. In zoom view all lines are still visible, not broken and the line weight must be 0.00 (Note. All my layers are in line weight 0.00)
Please see attached photo of the problem I encounter for reference using the format below.
  1. High quality print
  2. Microsoft print to PDF
  3. DWG to PDF
  4. Adobe PDF
  5. Export to PDF
PS. I also adjust the plot style table (pen assignment) and the PDF option for DPI but i had a same result.
Appreciate your help on this.
Thank you.
pendean
Community Legend
Community Legend
Nothing is attached: and pictures will not get you as much real help as you posting your DWG and PDFs either.
ronualdo_neral
hi @pendean  meaning there's nothing I can do to solve this?
Anyway here is the photo of the  using 2 formats (other formats have same result)
1. DWG to PDF
dwg to pdfdwg to pdf
2. High quality print
high quality printhigh quality print
pendean
Community Legend
Community Legend
@ronualdo_neral Share DWG file(s) please, and better explain your issue (and expectations with better examples) in more detail please, pretty pictures confirm your observation but do not reveal the underlying cause (I know you think you know, but we don't know you and we cannot confirm much of anything about them).
ChicagoLooper
Hi @ronualdo_neral
Try using this pc3:
Don’t make the rookie mistake by using ‘high quality’ pc3.  You only have linework and dims/mtext so comparing general vs. high quality will not reveal a visual difference.
If you still see fading in your plot then it could be a number of things occurring in your dwg or a combination of things so you’ll need to upload your dwg file.
Other areas open to evaluation that affect the plot include:
  1. Layer management
  2. Plot config
  3. Property overrides
  4. etc., etc., etc.
Chicagolooper
