AutoCad Table Text Editing
Message 1 of 8
I have a table in AutoCad with a cell that contains a lot of text.  I need to edit the font and color of several elements of this text.  When I try to pick items by the traditional method used in most other software (Ctrl - pick) it does not allow me to select multiple elements.  Is there a way to do this?
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
>>>...pick items by the traditional method ...<<< This is not Excel or any other spreadsheet program.
With AutoCAD TABLE elements, you can:
- Select a cell, then use PROPERTIES palette. If you use SHIFT when clicking you can select multiple cells, but they all have to be adjacent or other cells will get selected.
- Double-click inside a cell, then double-click the text to edit with the Ribbon or PROPERTIES function.
- To select multiple cells, you click then hold in one cell, window to capture all the cells you want to edit, then let go: when highlighted you can use PROPERTIES.
- You could just open TABLESTYLES command and fix your cell settings there, assuming there are no manual overrides in them of course.
Hope these help.
Message 3 of 8
pendean - thanks for the reply but maybe I didn't make myself clear enough.
As per attached screenshot I need to modify the font and color of certain portions of the text within one table cell.  Right now I can only do that by highlighting that portion and changing it one item at a time.  What I would like to do is select a portion, hit control and select another portion etc. etc.
Message 4 of 8
john.vellek
Hi @Anonymous,
I wonder if this would not be easier to do in an Excel spreadsheet which you could then DATALINK  into your drawing.
John Vellek
Message 5 of 8
pendean
Community Legend
Community Legend
In that case, you need to do what you discovered to be the only method in AutoCAD: or as others suggested, use Excel and link it into AUtoCAD so you can edit your table as you desire in the program you are most comfortable in.
Message 6 of 8
john.vellek
Hi @Anonymous,
Since there is no feature that will do what you are looking for, have you tried the Excel option?
John Vellek
Message 7 of 8
jeffrey_patton8NXHT
If you have the table in Excel or want to transfer it to Excel and back to a new CAD table this should make it so you can change the text with table styles
AutoCAD 2023
Before inserting cells from Excel, check the system Variable PASTESPECMODE :
  • Value 0 (default): Keeps the Microsoft Excel formatting.
  • Value 1: Inherits the cell formatting defined in the AutoCAD table style.
AutoCAD 2022 and earlier
Try the following:
  1. Insert the table by using TABLE command and creating a datalink.
  2. Click on the inserted table once.
  3. Right-Click on the table origin (rectangle that connects A-1) and choose DataLinks > Edit data link...
  4. In the modify menu, expand the window for "More options" (arrow symbol in lower right corner).
  5. Check/Uncheck "Use Excel formatting" depending on the preferred formatting.
  6. Click Ok.
  7. If the datalink is not intended (only table data), right-click on the table origin again > Data links > Detach data link and confirm.
Message 8 of 8
lineinc
Thank you for sharing your info, especially for sharing in a clear and non-cranky way!
I am inserting a data table from excel using edit>paste special>AutoCAD LT Entities and the only way I could figure out how to change the text color was one cell at a time. Changing PASTESPECMODE to 1 solved the problem. Thank you so much!
