AutoCAD Software not Responding
brianwclayton1969
brianwclayton1969
All my AutoCAD software are not responding. I have AutoCAD 2016 LT (license that is mine before going to subscription), and AutoCAD 2017, AutoCAD 2018 that are Student versions for school (I'm a instructor at a college). The AutoCAD 2018 worked last Friday, 3/2/18. Now when I open any one of the software, when you hover over any icon it acts like it will open a file or start a drawing (the icon will highlight or light up), then it hangs up and doesn't do anything. You have to hit CRTL+ALT+DEL to shut down the software.
I have shut my laptop down and restarted it.
Any answers would be greatly appreciated.
@brianwclayton1969
john.vellek has edited your subject line for clarity: AutoCAD Software
0 Me gusta
Responder
Soluciones aceptadas (2)
655 Vistas
8 Respuestas
Respuestas (8)
john.vellek
HI @brianwclayton1969,
This sounds like an awful experience. Are you on Windows 10 with the Fall Creators Update (.248 build)?  If so, try updating Windows with the latest updates (.251 build) that came out a couple days ago.
If you are on a different version, please tell me which one (use WINVER at the command line).
Please also tell me your graphics card make and model and driver version. Perhaps an update will cure this issue.
John Vellek
0 Me gusta
brianwclayton1969
No I'm NOT using Windows 10.....I'm using Windows 7, I have updated my Nvidia graphics Driver about a month ago. AutoCAD 2018 worked last Friday, 3/2/18.
Graphics Driver:
Nvidia GeForce GT630
Driver version: 23.21.13.9077
Driver date: 1/23/2018
0 Me gusta
WarrenGeissler
Hey @john.vellek does the /NOHARDWARE trick still work like >>HERE<<? That will at least get him rolling.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
0 Me gusta
No aplicable
This will sound silly, but have you tried uninstalling and reinstalling the software?
This has happened to me before in the past, and doing the above usually would fix it.
*First attempt at giving some support on here instead of asking questions, crosses fingers it goes well*"
0 Me gusta
john.vellek
HI @WarrenGeissler,
It is certainly worth a try but I believe the graphics driver is new enough that it shouldn't really be a problem with Hardware Acceleration.  I suspect that this is related to a Windows update and possibly a .Net issue.
I am hoping that @brianwclayton1969 will now provide the version of .NET Framework installed and also send me an NFO file.
I suspect that installing .NET Framework 4.7.1 might correct the problem.
John Vellek
brianwclayton1969
John I tried to attached the NFO File you requested.
This post website from Autodesk, it doesn't like that .nfo extension, how can I get this file to you.
Thanks for your assistance,
Brian
0 Me gusta
john.vellek
Solución aceptada
Hi Brian, Thanks for the System Information File.
At first glance, I suspect that WSCommCntr4.exe is the cause of the problem.  Here is an article that should help to correct this issue. Please let me know the results after trying these steps.  Since this is a laptop I would also suggest that you open the case and make sure all RAM modules are fully seated.
John Vellek
brianwclayton1969
Solución aceptada
John, Everything worked fine after your solution.
Brian
0 Me gusta
