AUTOCAD Selection within a Polyline
chrisjune1994
chrisjune1994
Hi all,
Ive got a large drawing (map) which includes several layers and different features. Ive inserted Polylines on top of the map which indicate a specific area and i want to select everything within that one area and exclude the rest so the data i export into excel only includes the points which are required. Easy enough to delete sections however the shape of the polyline is very irregular so finding a solution has been dificult. The closed ive got i think is by using the polygon command however i ant get it to work completely or the way i want it to.
Probably not explained in the best way but nay help would be greatly appreciated. Could post pictures if anyone thinks they could help
Chris.
Alfred.NESWADBA
this sounds like a typical GIS-task, so the question is do you have a GIS-application (e.g. AutoCAD Map 3D or AutoCAD Civil 3D or something like QGis) or just plain AutoCAD?
Is the data stored as AutoCAD geometry (so as DWG and not as GIS-datasets like SHP/SQLite/...)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
ВeekeeCZ
There are several routines upon this task. Very last one is made by @hmsilva here, post #10
Only thing that needs to be change is this line
(command "_.erase" ss1 "_R" ss "")
to this line
(command "_.select" ss1 "_R" ss "")
... then it's stored as "previous" selection.
The simpliest solution I can think of in AutoCAD 2016 is to use the lasso selection mode. This of course if your polyline shape is not too complex.
Or you can use a bit of LISP like Serge Camiré code:
(setq plineSel (entsel "\nChoose the polyline: "))
(setq pline (car plineSel))
(setq plineGet (entget pline))
(setq vertex (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) plineGet)))
(setq ss (ssget "_wp" vertex)) ; //(or _CP)
vladimir_michl
You can use the WPS utility and enter 'WPS on any "Select objects:" prompt. See:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5697
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
