AutoCAD - Select Object, Right Click Drag, then "Move Here" is not working
jan.concepcion
jan.concepcion
I have my CAD set such that when I select objects and click+hold right click and drag the mouse, usually, the objects would visually be dragged to follow my mouse cursor. When I release the right click, a menu pops out with 3 to 4 selections, two of which are "move here" and "copy here". I've been using this for quite some time and it is my preferred way of moving objects when I don't need to be precise. Now, this no longer works. Instead, when I select the objects, and click+hold right click and drag the mouse, the objects stay in place and no longer follows my mouse. When I release the right click, I get a longer menu with no options to "move here" or "copy here". See image below of the differences.
I want this:
I don't want this:
[ The subject line of this post has been edited to include the product name by @handjonathan ]
imadHabash
I suggest to check  PICKFIRST system variable .
Command: PICKFIRST
Enter new value for PICKFIRST <0>: 1
Imad Habash
jan.concepcion
PICKFIRST was already set to 1
imadHabash
would you please restart AutoCAD and check PICKFIRST system variable , any changes?
Also you can from OPTIONS command >> User Preferences tab >> Right click-customization
Imad Habash
jan.concepcion
I restarted AutoCAD and changed the PICKFIRST system variable from 1 to 0 to 1. The issue has been resolved. Thank you.
