AutoCAD Forum
AutoCAD - Seeking press pull bug workaround
2 REPLIES 2
20055423ZY6Q8
343 Views, 2 Replies
20055423ZY6Q8
Will not extrude an area, sometimes will not extrude two areas in the drawing.
Is there a leaky sketch fix tool?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Tags (2)
2 REPLIES 2
TheCADnoob
in reply to: 20055423ZY6Q8
TheCADnoob
When i redraw this line it seems to work fine.
CADnoob
CADnoob
vinodkl
vinodkl
Hi @20055423ZY6Q8
you can create a boundary of the area and then use than boundary to extrude. See below screencast 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi @20055423ZY6Q8
AutoCAD Inside the Factory
