AUTOCAD-RIGHT WINDOW SELECTION
cturlington
cturlington
I am using AutoCAD 2016.
I have been able to create a right window selection in the past.  But lately, I have been unable to select anything using a "right" window.  Is there a setting that turns this ability on/off ?
Responder
Soluciones aceptadas (1)
975 Vistas
5 Respuestas
Respuestas (5)
No aplicable
What is a right window selection?
0 Me gusta
Darin.Green
Type PICKADD at the command line, then set the value to 1
If this information was helpful, please consider using the Accept Solution
0 Me gusta
Kent1Cooper
Do I assume correctly that you're talking about picking a window in the rightward direction [second corner to the right of first corner], for a fully-contained-in-the-window selection rather than a crossing-the-window selection?  If so, are you talking about selecting without a command active [Darin.Green's PICKFIRST suggestion], or at a Select-objects prompt within an active command?  Does leftward crossing-window selection work when a rightward window doesn't?  I'm not aware of any setting that would affect one but not the other.  Does individual item picking work?
Kent Cooper, AIA
0 Me gusta
cturlington
Darin,
Thanks for that idea.  However, the right window; selecting a screen location with cursor starting in upper right corner, then selecting lower left is simply not available, nor left window by picking from lower left to upper right.  I can only pick items individually.  Unfortunately the PickAdd and PickFirst settings do not have an impact on this performance.  Any other suggestions I am all ears ?
0 Me gusta
sthompson1021
Solución aceptada
OPTIONS-Selection Tab,  Make sure that implied windowing box is checked.
