Announcements
AutoCAD Publish Problem
I have more than 1000 dwg drawings which i want to convert to Adobe PDF,
I am using AutoCAD 2015, and batch plot tool.
pls find attached screenshots.
but after Publish. Error: None plot device. Configure a valid device before plotting.
Nitinmh40
The error says enough
Just set a plot device where the dwg's can be send to so that it can be plotted
You can set a device if you start a new dwg --> go to plot --> add page setup and configure that page setup
Now when you go to publish remove all dwg's up there and add only your dwg's
now choose at page setup "import" and import the page setup you just made in the other dwg
If you have any question let us know
Regards
Don
thanks for reply,
pls find attached screenshot.
page is already set up. I added new drawings but when importing page setup it asking for path,
what is file extension for page setup file and where page setup file is located?
pendean
Community Legend
Community Legend
Pagesetups are imported/found/saved in your template file(s): DWG like the last screen capture shows at the bottom of that popup or DWT (use that bottom entry Pulldown to change it).
Thanks, I created new .dwt file and then imported. worked.
but selected two drawings getting saved in single adobe pdf file and I want to make different pdf files for different dwg files.
pendean
Community Legend
Community Legend
That's a setting in the PUBLISH pop-up's OPTIONS button.
