AutoCad Programs And Windows 11
javier.zavala
javier.zavala
I'm currently in I.T should I bother trying to upgrade the machines to windows 11? I'm afraid it will cause problems with Autocad Versions 2019 and Above What do you guys think???? Have you seen any big problems or problems that still haven't been fixed
pendean
Community Legend
Community Legend
2021 and newer are what Autodesk will support in Windows11: anything older and it is all on you to make things work (most find it works just fine, others find the OS upgrade quite crippling).
if you need documentation, then... https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Will-AutoCAD-based...
