Hi Guys,
i have googled on this issue numerous time and found noting...so this one is for Experts
if you have (let's say) 2 profiles with some differences between them, when you change profiles (set current)
AutoCAD will apply some (if not most of them) settings from the current profile to the target profile.
i have discovered this last night when i tried to create another profile (beside <<Unnamed Profile>>)
with a different application loaded list on APPLOAD. on each profile switch, AutoCAD is coping the loaded application list to the target profile
i have also checked to see if this is done to other settings and found it is true!
this 'bug' is crossing version and it looks like AutoDesk does not aware on this.
Thanks in advance for your educated answer
Moshe
