My problem is that when I move dimensions in my drawing, text and line of dimension moves, together with dots which with dimension is defined. How can I make the dimension dots not move when I want to move text and line? Is there a way to fix them on the spot of my drawing, where I want my dimension to be defined.
And another question when I already made a damage to my drawing (when I moved dimension lines together with its dots, now dots are all over my drawing. And now when I want to put dots on it's place, the "stretch" command works really well - I move dots and dimension line and number stay in place, but when I need to "lengthen" my dimension, and move dots on it's place, it moves line and text too. Is there a way to move dimension lines without moving dots? And I don't need answer "move it one by one", because I need to do it for group of dimensions. 🙂
Thank you
Best regards
