autocad plot/print hızı çok yavaş.
grfkpc
Message 1 of 8
grfkpc
Until 2 or 3 months ago, I was able to get very fast while printing with autocad. It was torture to print now. I have to wait 21 seconds to print from each file. I know the option to show the print screen, but I don't want it to print in the background.
I would appreciate if you help. I use autocad 2017, my computer is fine. I have no systemic problems.
as follows..
thanks in advance for the help.
Replies (7)
Message 2 of 8
imadHabash
make sure please that you select a plotter end with  .pc3  from PLOT dialog .
Imad Habash
Message 3 of 8
pendean
Community Legend
Community Legend
Did you by chance turn on background plotting in OPTIONS command?
Os is this a new printer/plotter, or a new server but same old printer/plotter, or are you just now working remotely for example?
Message 4 of 8
grfkpc
Merhabalar,
PC3 olarak çıktı alıyorum. daha önce olduğu gibi.
teşekkürler ama çözüm olmadı.
Message 5 of 8
grfkpc
arka planda çıktı alma seçeneğim kapalı.
yeni printer, yeni server değil. uzaktan çalışmıyorum.
aynı server da başka arkadaşım hızlı çıktı alabiliyor.
çözüm olmadı, saygılarımla.
Message 6 of 8
Alfred.NESWADBA
do I understand this correct, the issue started with a new printer?
And ... does the same slowness happen when you select "AutoCAD PDF (Web and Mobile).pc3" as output device?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 8
grfkpc
merhabalar,
Printer yeni değil. Yıllardır aynı printer ı kullanıyorum.
Dediğiniz gibi "AutoCAD PDF (Web and Mobile).pc3" olarak denedim. Gayet hızlı pdf oldu.
Fakat 1 printer ve 1 plotter cihazımız var. ikisinde de sorun aynı. çok yavaş baskı alabiliyorum.
Message 8 of 8
Alfred.NESWADBA
if plot to PDF works fast, but plotting to the other devices does not, then you might
  • check driver versions for your printer/plotter
  • check permissions for these devices
  • create new PC3 files for them
When you say that your colleague can plot fast, did you try the exact same dwg-files?
- alfred -
Alfred NESWADBA
