AutoCAD Parametric help/tip
So I'm very familiar with parametric constraints in 3d (ProE/Creo + Inventor) but using ACAD to model 2D parametrics is frustrating. Maybe its me or my style but without DRAFT or POINT abilities I am finding it annoying and a slow process.
Namely cause the Parametric tools aren't recognising intersections as a reference; seems only to identify Ends, Centres and Midpoints.
My solution has been to create a DRAFT layer (offset -Z from final) to construct my draft construction and create the parametric relationships. Then essentially the final layers are a trace of the draft and parametric (=) relationship.
Surely this isn't the best method or the way its intended for use in 2D. Likewise modelling something in 3D to create a simple 2D plan drawing seems counter-productive for small scale tasks.
Any help or insights are greatly appreciated.  Thanks in advance.
leeminardi
"Namely cause the Parametric tools aren't recognising intersections as a reference; seems only to identify Ends, Centres and Midpoints."
To reference an intersection point in AutoCAD's Parametrics I have added a very small circle that has a tangent constraint to both lines.  You can then add a dimensional constraint to the center of the circle.  This workaround provides surprisingly good results.
Lee
lee.minardi
Thanks for that piece of advice. It seems somewhat counterintuitive tho to
having a streamlined design process.
Is there a train of thought to introduce a point or intersection reference?
Perhaps even a toggle for auto-parametric mode? Where any drawings are
automatically constrained as per draft/sketch modes in Inventor/Creo?
The parametric tool in AutoCAD seems gimmicky or aimed as an entry level
introduction, rather than a fully functional feature.
WarrenGeissler
Infer geometric constraints in the Constraint Settings dialog:
Definitely a good wishlist item! You should post wishlist items at the product feedback portal >>HERE<< and/or at the AUGI wishlist portal >>HERE<<
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
leeminardi
"The parametric tool in AutoCAD seems gimmicky or aimed as an entry level introduction, rather than a fully functional feature."
I wouldn't classify AutoCAD's parametric tools as gimmicky.  They are pretty much limited to 2D use similar to the constraints in Inventor's sketch mode.  I've used them in a variety of applications.  Here is an example for modeling a 4-bar linkage.
https://youtu.be/Y4VAJ5mNnng
The attached drawing is an example where I used a small circle to identify the intersection point of two lines to model the kinematic action of an "invisible hinge".
Lee Minardi
lee.minardi
