AutoCAD page setup manager issue
No aplicable
I am trying to print using AutoCAD page setup manager. Everytime I close the AutoCAD i have to setup another page setup for giving prints. How can I save the particular page setup as default such that I dont have to setup again and again.
0 Me gusta
Responder
246 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
If you start _PAGESETUP ... you can't print from that command. What command exactly do you use to print?
Are you speaking about the same dwg-file? Because creating a pagesetup is only saved in that dwg-file you have created it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
RobDraw
If you create a named page set-up it can be imported into existing files.
If you store the page set-up in your template file, it will be available on future files created from that template.
I usually keep a file handy that has most of the page set-ups that I use for easy importing.
Rob
0 Me gusta
