AutoCAD - Osnap keyboard shortcuts missing a click
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I've been using ACAD consistently since the DOS based release 10 and have come across an intermittent problem that I believe started in AutoCAD 2022 and still persists in 2023.
I often use keyboard shortcuts for osnaps that I don't want on as default, such as 'nearest'.
I have found that sometimes when I type 'nea' and hit enter (it can be any osnap not just nearest) it shows the correct autosnap marker symbol and I pick a point, however it hasn't actually picked anything. I then pick my second point for displacement (if using a modify command) and it becomes the initial base point. Very annoying as this has never previously been an issue.
I can replicate the issue......somewhat, and it always corrects itself if I do the exact same operation again.
I thought it was an issue with my mouse's left click button but the above situation seems to be the only time there is ever an issue.
Anyone else had a similar issue?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Osnap keyboard shortcuts missing a click ]
