Autocad opens a new autocad everytime I open a drawing.
dvrVSNMW
dvrVSNMW
Hello, (asking for a co-worker)
If I open a DWG. Autocad opens. Easy.
But If I open another DWG, a new autocad opens. It does not open in the already open autocad.
Anyone knows how this comes?
I have set autocad to open with the next program. (autocad application red button)
With this, every time a new autocad opens.
If I open with DWG laucher, I get next error message:
And I have OEM 2024 de-installed.
0 Me gusta
Responder
Soluciones aceptadas (2)
881 Vistas
10 Respuestas
Respuestas (10)
Valentin-WSP
Solución aceptada
@dvrVSNMW ,
Take a look at @Emmsleys suggestion HERE.
Related:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
dvrVSNMW
U are talking about the taskbar. That is not the problem. The problem is: everytime I open a new drawing. A full new autocad program starts opening. It should just open the 2nd drawing in the - already open - autocad.
0 Me gusta
cadffm
But aclauncher (what is the right program to open .dwg) still remembering the AutoFloor OEM 2024 as 'last used Program to open a .dwg).
Do have access/writerights to the registry?
Find and replace the wrong path with the right one..
C:\Program Files\i-Theses\AutoFloor OEM 2024\Afloor.exe
with
C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe
Sebastian
0 Me gusta
dvrVSNMW
Where in the registery do I have to be?
Do you know what path I need to start/look for?
0 Me gusta
cadffm
C:\Program Files\i-Theses\AutoFloor OEM 2024\Afloor.exe is obsolet, so you can do it everywhere.
Sebastian
0 Me gusta
dvrVSNMW
Ok, we made progress. At first we got always a error with OEM. We installed it again and removed it again. Now the AClaucher opens autocad.
Only problem is that this launcher always launches a new autocad program. So if I open 3 drawings, I have 3 autocads running. Is that an issue I can fix?
0 Me gusta
dvrVSNMW
Solución aceptada
Ok, problem solved.
I only had to set SDI to "0" and it opens all the drawings in one autocad now. Thx for the help.
0 Me gusta
Valentin-WSP
@dvrVSNMW ,
Suggested on message 2.
Emilio Valentin
dvrVSNMW
Yep, I see now. My bad.
It is a lot of info and problems you have to process.
Thanks for the help Valentin.
0 Me gusta
cadffm
OFFtopic.
Please use the [REPLY] Button and not the stupid fast-reply-field,
so we can follow you and know to who you are replying.
Sebastian
0 Me gusta
