Autocad opening multiple session every time trying to open a new DWG file
Message 1 of 16
Dear Sir/Mam,
This is to find solution for a problem with my Autocad 2016.
Everytime i try to open a new DWG file, Autocad opens the same in a new session. This is very annoying as we need to work on multiple files at a time and opening new session everytime, reduces system performance and decreases efficiency. I have also checked SDI to be 0, and also reinstalled my Autocad 2016.
Please suggest a solution.
Thanks and Regards,
Alekh Verma
Replies (15)
Message 2 of 16
RobDraw
Open file from AutoCAD, not from File Explorer.
Rob
Message 3 of 16
nrz13
What operating system are you using?
You get two separate AutoCAD windows or just two instances on the Windows taskbar?  Note that the taskbar in Windows 7, 8/8.1, and 10 shows individual documents in programs as separate instances on the taskbar.  To disable AutoCAD from doing this, set TASKBAR to 0 instead of 1.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 4 of 16
RobDraw
The Windows setting can also be changed to stacked, showing all open drawings in one taskbar icon location.
Rob
Message 5 of 16
Emmsleys
@Anonymous,
Were you able to resolve the issue you were having by the suggestions made in this thread? If so can you please mark the appropriate post/post's with the Accept As Solution.
If you are still having this issue you can also try the following;
If SDI is already set to 0, try re-associating . DWG files with the AutoCAD DWG Launcher as per the instructions in DWG file type associativity in Windows
It may be that AutoCAD and the AutoCAD DWG Launcher need elevated permissions. To do this:
  1. Locate the following two files:
    C:\Program Files\Autodesk\AutoCAD 20xx\acad.exe
    C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe
  2. Right-click each file and choose Properties.
  3. Click the Compatibility tab.
  4. Set the option at the bottom to run as administrator. Click OK.
In some circumstances AutoCAD needs to be reset to defaults (see How to reset AutoCAD to defaults).
If double-clicking a DWG file doesn't launch AutoCAD at all, please refer to Double-clicking a DWG file fails to launch AutoCAD.
There is also another thread that had a similar issue and can be viewed here and here
Sarah Emmsley
Technical Support Specialist
Message 6 of 16
dhaverstick
I have experienced a similar situation with AutoCAD Mechanical 2018. To fix the issue, I had to go into the registry and change a couple of keys.
There are some reg keys down the path of HKEY_CURRENT_USER\Software\Autodesk\DwgCommon\shellex\apps. Find the one for AutoCAD Mechanical. It will reference "ACADMPP".  Look at the values for OpenDdeSvc and PrintDdeSvc. Both of mine had the value of AutoCAD.r21.DDE. I changed that value to AutoCAD.r22.DDE (which is the 2018 version) and the problem was fixed.
Darren Haverstick
Paul Mueller Company
Message 7 of 16
SorinBrie4666
Community Visitor
Community Visitor
Combining tabs still does not solve the issue of how to avoid two sessions o Autocad being opened - issue is still unresolved as far as I am concerned. This is a matter of performance for the pc. How do we stop the un-used session from opening??
Message 8 of 16
RobDraw
Open the drawings from within AutoCAD.
Rob
Message 9 of 16
If the problem remains while your system variables were:
- in AutoCAD: SDI set to 0
- in AutoCAD: TASKBAR set to 0
- in Windows: DWG files are already associated in Windows with the "AutoCAD DWG Launcher" application
- in Windows: acad.exe is set to "Run this program as an administrator."
To completely solve the problem:
1. Locate AcLauncher.exe at its installed directory (usually C:) :
"C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe"
2. Right-click on the file and choose Properties and then the Compatibility tab.
3. Toggle the setting "Run this program as an administrator." and then click OK.
Good Luck...
Message 10 of 16
pjfontes
ACAD Electrical 2018, Win10 w/beyond-trust
None of these methods worked for me.   Hopefully this reply will be helpful for others who are stuck.
I was finally able to get AutoCAD 2018 to launch correctly by deleting extra entries (seen as "folders") found in:
HKEY_CURRENT_USER\Software\Autodesk\DwgCommon\shellex\apps\
using regedit, if you click on each funny-named 'folder' (eg. {80B0F5DE-B452-44bf-A155-2467B0E9D531}:ACADE) you will see paths associated with autocad.
in my case, I deleted the entire 'folder' for which 'OpenLaunch' was pointing at ACAD 2014.  FINALLY solved my issue!!!
Message 11 of 16
pjfontes
Darren Haverstick
^^^^^^^^^^^^^^^^^^^^!  This ^^^^^^^^^
Message 12 of 16
dascorpus
Go to any dwg file in the File Explorer right click select properties and click change on 'Opens with' and select AutoCAD DWG Launcher instead of AutoCAD Application.
Message 13 of 16
This actually works.
Thanks !
Nick
Message 14 of 16
thank you, it worked for me.
Message 15 of 16
Kevin.0rtiz22
Thanks, man, this is what I've been struggling in silence with for years, and only now I looked for a solution and found it thanks to you.
Message 16 of 16
ignacio_rojas_garcia
Observer
Observer
This worked for me. Thanks!!!!! AutoCAD.r22.DDE is 2018 and AutoCAD.r24.DDE is 2024 version of AutoCAD
You have to change this:
https://www.autodesk.es/support/technical/article/caas/sfdcarticles/sfdcarticles/ESP/Error-Windows-c...
But using the correct version. Just that
