Anuncios
AutoCAD network bandwith usage
wim_de_winter
wim_de_winter
When i copy a dwg file with Windows Explorer from a server to my pc, the process uses 100% capacity from my LAN network.
When i open the same dwg file stored on a server with my local AutoCAD there is only 15% capacity in use from my LAN network.
Why does AutoCAD not use the 100% bandwith from a LAN network when open files, just like copy command from Windows Explorer?
It's on different network enviroment's in different company's.
AutoCAD never open drawings with 100% bandwith use.
Why?
Wim
0 Me gusta
Responder
671 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
copying a file does not need to check the content, create a memory image from the content, display the file's content in color/linetype/on layers/in layout/evaluate hatch borders .... but all this is done when AutoCAD opens a file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
wim_de_winter
Open a file from a local harddrive is faster than open from a network drive. It seems that not using more than 50% bandwidth is the bottleneck.
Wim
0 Me gusta
