Anuncios
AutoCAD MEP Duct Centerlines
mattm7F3YZ
mattm7F3YZ
I am working on a project in which we received Autocad drawings of the existing duct layouts. My plan was to copy and paste their modeled content into our drawing template (AutoCAD 2021) to maintain all of our standard settings.
The problem is that when I paste it into our drawing template, the duct (model category shows it as a "3D Object") displays a centerline which I do not want to see (see attached drawing). In the original drawing that we received, the centerlines of the ducts are not being displayed (see attached drawing). I can't seem to figure out which setting they have enabled/disabled to turn off the centerline.
Any help is much appreciated!
Thank you,
Matt M
0 Me gusta
Responder
Soluciones aceptadas (1)
529 Vistas
2 Respuestas
Respuestas (2)
fatal.error
Solución aceptada
Please set ISOLINES system variable value to 2 and type REA to regen all.
This variable specifies the number of contour lines displayed on the curved surfaces of 3D solids.
Valid settings range from 0 to 2047. Initial value is 4.
0 Me gusta
mattm7F3YZ
Perfect! Can't believe it was that easy. Thank you for the help!
