AutoCAD - Match Attributes table from 2 cad drawings
aazzouhri
Observer
aazzouhri
Observer
Observer
Hi Everyone. I'm trying to much the content of the attribute table 1 (The filled one) to the new empty cad drawing like the installation date on installation date and so on. any solution fir that pleasCad Table 1.JPGCad Table 2.JPG
[The subject line of this post has been edited for better findability by @handjonathan Original: Match Attribute table from 2 cad drawing ]
Responder
303 Vistas
3 Respuestas
Respuestas (3)
jamatuseski
An easy way to bring Object Data Tables into your drawing is just by dragging a drawing know to contain the tables into the view frame of the drawing you wish to add the tables to.
Once you are asked to specify insertion point, simply press ESC.
aazzouhri
Observer
Observer
Thank you for the replay
I'm not really familiar with AutoCAD can you please show me the steps I appreciate
jamatuseski
Please see attached for a quick video. I cant recreate your scenario exactly as I use Map 3D to work with this data and you appear to be using the ArcGIS extension for AutoCAD, that said, this should get the tables in your drawing, from there the workflow will be within your ArcGIS extension.
