AutoCAD LT generate Circle from arcs
Message 1 of 11
Hi
I receive often drawings where circles are formed trough 2 or 3 arcs. Is there a command in autocad LT to convert it  to 1 circle?
Replies (10)
Message 2 of 11
jayhar
did you try JOINT command ????
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 11
No JOINT command in LT. tried JOIN but it generates one arc, still not a circle
Message 4 of 11
jayhar
Can you please upload AutoCAD 2013 format
and follow this link https://grabcad.com/questions/arc-convert-to-circle-in-autocad
Jayhar.M.J
Message 5 of 11
cadffm
Two things:
1. " but it generates one arc, still not a circle"
An ARC ? In my test you get an arc just if ou are far away from a fill circle, please upload ONE sample.
(all rules "how join command works, depend of selected objects" are too much here and now)
2. If you have multiple times "two arcs as circle"
 The way by JOIN only works when selected just one "circle" (= two arcs).
  Hint: Command: multiple, join, select your two arcs<space hit><space hit>
            and so on until you cancel[ESC] the loop.
 when you select multiple situations like this at once, Join creates closed polylines.
As LT User i would do what i whould often do:
a) Using DXF-ascii Format and do the change by texteditor
 or
b) Use another CAD program, they start at 0.00$
Sebastian
Message 6 of 11
pendean
Community Legend
Community Legend
No.
For future reference the AutoCADLT forum is over here where you will not get non-LT advise typically unless you insist on it https://forums.autodesk.com/t5/autocad-lt/ct-p/2000
Message 7 of 11
Kent1Cooper
In full-AutoCAD 2019, in the JOIN command, if you select multiple Arcs that form a circle, it notifies you of that and asks whether  you want to convert them to a Circle [entity].  If it's not  asking that [and if  JOIN in whatever version of LT you use works the same as in full Acad2019], then the selected Arcs don't form a true circle, whether because they don't share exactly the same center point and radius, or because their ends don't meet precisely, or maybe for some other reason(s).
Kent Cooper, AIA
Message 8 of 11
Kent1Cooper
@Anonymous wrote:
.... tried JOIN but it generates one arc, still not a circle
In that case, they must not quite meet at one end.  An Arc [that is, an AutoCAD Arc entity] cannot go around a full 360 degrees and be "closed" with both ends at the same place.
Kent Cooper, AIA
Message 9 of 11
cadffm
@Kent1Cooper ?
Join command can create a circle from two arcs, when both (four) endpoints match 100% and
also wenn just one (two) endpoints match.
The gap can be up to 179° (with such a big gap you have to select the little arc as first).
Or did i unserstood your answer incorrect?
Sebastian
Message 10 of 11
Bob_Zurunkle
OP did you try the following:
1. Eliminate all but one arc in the "circle"
2. Use the join command and pick the arc
3. Read the command line and pick the option cLose (or L for short)
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 11 of 11
Kent1Cooper
I confess I hadn't tried it with Arcs that don't  completely fill the circle, but yes, JOIN can complete it even when they don't [provided they have the same center and radius].  However, I was going from their description in Message 3 that they had "tried JOIN but it generates one arc, still not a circle,"  in which case something else is going on -- it may be only that they didn't notice JOIN's option to complete the Circle.
Kent Cooper, AIA
