autocad lt 22 fatal error:unhandled access violation reading 0x263f7158 exception at 17AE07A5h
caddbuddy88
caddbuddy88
i don't know how to fix it. The computer updated and when it came back up I tried to open Cad and this is what i get. i even shut the computer down and restarted. I updated graphic card but it says it has the latest drivers. all help is appreciated.
Replies (12)
paullimapa
You could try resetting LT
If that still doesn't work, create another local admin windows account, sign in as that account and then try running LT
Paul Li
IT Specialist
@The Office
caddbuddy88
i can't get into cad it opens a to a drawing 1 but nothing works it's faded out.  You can't click on a icon you can't close it. it's basically frozen.  How do you create a new a new window admin account?  I hope this isn't an on going thing with this computer updating it will drive me crazy. lol
paullimapa
Resetting AutoCAD LT does not require you to open it. Did you try that yet as I posted the link in my first reply?
Heres info you can find online on how to create another Windows user account
Paul Li
IT Specialist
@The Office
caddbuddy88
yes i did was not successful.
paullimapa
Then install lt 2025 which saves as same format and supports lisp to see if that runs
Paul Li
IT Specialist
@The Office
caddbuddy88
I would have to buy 2025 in order to use it. Correct?
paullimapa
You should be on subscription already with LT 2022 so you have the rights to install the current version and up to three versions back.
Paul Li
IT Specialist
@The Office
caddbuddy88
NO I HAVE A STAND ALONE LICENSE . I DID HAVE A MAINTENANCE PROGRAM FOR YEARS WELL UNTIL 2022 THEN I WAS TOLD IT WOULD NOT BE AVAILALE AFTER THAT. I PAID EVERY YEAR THEN THEY COME UP WITH SUBSCRIPTION/LEASING LICENSES AND PUT A STOP TO THAT.
paullimapa
You can always download and install the 2025 trial and see if it works.
Paul Li
IT Specialist
@The Office
edwin.prakoso
If you are sure a recent Windows update is the culprit, you can try uninstall the update and see if it works. It happens occasionally that a Windows update breaks a software. Usually Autodesk soon will release a hotfix or update if the version is still supported.
Cheers,
Edwin Prakoso
caddbuddy88
Is AutoCAD LT 22 version I’ve been down for a while and can’t seem to get this solved.
paullimapa
Since your OP stated:
The computer updated and when it came back up I tried to open Cad and this is what i get…”
Read @edwin.prakoso solution again and try it.
Paul Li
IT Specialist
@The Office
