AutoCAD LT 2019 accoreconsole missing/unknown command
No aplicable
Does anyone knows if there have been changes from the acoreconsole in AutoCAD 2013 to AutoCAD 2019 LT?
My problem it's that I'm trying to run a script that converts a drawing from DWG to WMF, this scripts works perfectly in 2013 and my computer just got an OS reinstall and I have the latest AutoCAD version at my company (2019 LT). When I try to run this script it looks like the WMFOUT is not available anymore an a unknown command message is displayed.
Would you guys be kindly to help me? I would appreciate it a lot.
Here's a screen shot of the running console trying to run the WMFOUT command.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.069 Vistas
9 Respuestas
Respuestas (9)
rkmcswain
FWIW - the documentation for 2019 LT still includes this command.
http://help.autodesk.com/view/ACDLT/2019/ENU/?guid=GUID-6B7ECC84-F2D5-402C-8719-E8FE2171AE96
0 Me gusta
No aplicable
I posted the image and does not seem to be working. Do I have to run another command before run WMFOUT. I read about loading dbx files/modules.
0 Me gusta
pendean
Community Legend
Community Legend
From your screenshot it seems WMFOUT command is not recognized, that's probably the issue.
What's your script's code/content?
0 Me gusta
cadffm
pendean 'From your screenshot it seems WMFOUT command is not recognized, that's probably the issue.'
Thats not the issue, that's the question in the Thread.
"Does anyone knows if there have been changes from the acoreconsole in AutoCAD 2013 to AutoCAD 2019 LT?"
" works perfectly in 2013 ... at my company (2019 LT). When I try to run this script it looks like the WMFOUT is not available "
@Anonymous
I can not help you with 2019, but here is my comment:
1. With my 2019 (not LT) it's the same, ootb the WMFOUT command is not available in ACC.
2. Tested with the newer 2020 version: WMFOUT works in ACC.
1* OFFtopic.
Why you are running an obsolet version, current product version is 2019.1.2 (Vernum P.164.0.4)
Sebastian
0 Me gusta
pendean
Community Legend
Community Legend
@cadffm I was agreeing with the OP ,then continued to ask about the script content they where using so we can try it ourselves. Sorry if my phrasing was confusing.
WMFOUT works fine OOTB in LT2019.1.2 here when launched, no issues with it.
cadffm
In that case, I apologize better to you, I sometimes have problems with the translation and interpretation. :cara_que_abraza:
The minimum Script content you need to test is a line with WMFOUT,
i am sure you get the name 'unknown command' message if you run the accoreconsole 2019
;;;STARTSCRIPT
WMFOUT
And if you don't use the logfile, you can start the script by using a *.bat and pause the cmd sequence to read the console window.
Ready test package attached (hardcoded path to D:\ for dwg and scr file, edit the path in *.bat file if needed)
Sebastian
0 Me gusta
No aplicable
Thank you so much in your effort to post this attached message.
Sadly It didn't work I changed the path of the CMD executable.
The command works with a normal AutoCAD window with the full GUI but I think the accoreconsole it's the buggy one.
0 Me gusta
cadffm
Solución aceptada
With all my answers i confirm that, never wrote the opposit.
It works in 2013 for example and in 2020 again, but not in 2019(.1.2)
Sebastian
0 Me gusta
No aplicable
Alright.
Thank you so much again...
0 Me gusta
