AutoCAD - Line Segments
cturlington
cturlington
I am using AutoCAD 2017.
I have set my max hatch scale by a system variable "MaxHatch" which works nicely for keeping annotative hatch visible in a particular view.  However, I would also like to keep my hatch boundaries linework from disappearing from view.  Is there a similar setting for setting the max line segments that can be viewed at a particular scale ?
0 Me gusta
Responder
Soluciones aceptadas (1)
411 Vistas
4 Respuestas
Respuestas (4)
Alfred.NESWADBA
What type of "linework" are the borders? If they are polylines/lines/arcs/splines then these objects don't have an annotative setting, so they can't appear/disappear depending on scales.
So the questions are:
  • which type of objects are the boundaries
  • when do they appear, when do they disappear
  • can you upload the drawing so we can test this on our workstations?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
cturlington
Attached is the hatch and linework.  The hatch boundary linework are polylines.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Thank you for the drawing!
Looking to the drawing I see:
  • coordinates in a very high area
  • hatches with billions of points
  • polylines with thousands of vertices
...all together handicaps for AutoCAD's display performance!
Anyway: I was able to reproduce the issue, that the polylines (the ones with high numbers of vertices) disappears with a specific zoom factor.
On my system I could get rid of it by starting command _GRAPHICSCONFIG and disable the option "High quality geometry (...)"
HTH, - alfred -
Alfred NESWADBA
pendean
Community Legend
Community Legend
If you are able, move your drawing closer to 0,0,0 and your issues should go away, since it is currently 2.3million+ feet away from those coordinates.
0 Me gusta
